6th Gen ('00-'05): Amplifier Getting Hot
Old Dec 15, 2019 | 07:07 AM
Mike Palatka's Avatar
Default Amplifier Getting Hot
My uncle has an 2002 SS Monte and the amplifier will work for a work for a while and shut down. He is wondering if there is a way to keep it cool.
Old Dec 15, 2019 | 08:54 AM
The stock amplifier? Hooked to stock speakers?
Something is wrong if its getting so hot its shutting off if that's the case.
Old Dec 23, 2019 | 07:10 PM
BIGSKELTER420's Avatar
You need to get a new applifier. If you still have the stock amplifier hooked up to the stock system you may want to upgrade 2 an after market 4 channel amp for your front and rear soeakers . if you have an after-market amp then you need to replace that. you get what you pay for so if you get a cheaper amp those are going to overheat way quicker than if you get a quality amp and spend a little bit more money
Old Dec 24, 2019 | 09:54 AM
Default Thanks
I told my uncle the same thing.
drjesus616
Oct 18, 2010 08:57 AM
MIKE07083
Aug 16, 2010 12:49 PM
paintballerr78
Dec 10, 2009 09:40 PM
victoryred05
Feb 3, 2006 10:04 AM
victoryred05
Dec 2, 2005 02:21 AM
