Air Compressor Starts then stops
Old Apr 2, 2012 | 11:21 AM
montecarloowner's Avatar
Default Air Compressor Starts then stops
When I turn on the car, the air compressor will start and run for a few seconds, but then stops and won't come back on. Does anyone have any ideas what might be causing this?
I also have some other problems such as the cruise control and heated seats don't work. I recently replaced the ignition switch, but that didn't fix any of my issues.
Any help is much appreciated.
Old Apr 2, 2012 | 11:36 AM
Probably is low on freon, the freon has oils that lubricate the system, so when you are low the compressor shouldn't kick on so it doesn't get damaged.
Old Apr 2, 2012 | 11:43 AM
I didn't know that. Do I have to take it somewhere to find out, or is there a way I can check the freon level myself?
Old Apr 2, 2012 | 11:57 AM
It is recommended to have a professional do this, we have closed systems, so if you are low then you most likely have a leak.
Old Apr 2, 2012 | 12:43 PM
Thank you for the help :-)
Old Apr 2, 2012 | 01:01 PM
No problem
1988BlackMonteCarloSS
Nov 21, 2014 12:05 AM
SgtWyatt
Mar 12, 2012 09:44 AM
mooke46
Oct 2, 2010 04:39 PM
dirty mech
Jul 24, 2010 01:17 AM
ChevRev34
Feb 24, 2008 01:10 PM
