Adjusting headlights?
Old Jan 27, 2011 | 12:43 PM
MJClemm's Avatar
Default Adjusting headlights?
Hello Guys, anyone here ever adjust your headlights? Mine seem to be a bit to high and Id like them to aim a bit lower... ANY info would be great. Also, WHAT is that hole in the middle (back of the headlight) with a what looks like an emty vacuum line? If no one knows what I mean, Ill take some pictures... thanks again...MJC
Old Jan 27, 2011 | 01:27 PM
not sure what you mean but the hole, but behind the low beam you should see a screw, just turn that and the beams will raise and lower, it's easiest to do at night with the light on so you can see where the light is at
avendo
Jan 18, 2018 05:45 PM
MonteCarlSS
Dec 6, 2012 11:19 PM
DV8168
Jan 15, 2011 01:06 PM
kyle08
Aug 29, 2006 10:43 PM
dagibbo
Dec 12, 2004 09:51 PM
