ac controller/2001 MC SS p/n
Old Sep 12, 2008 | 02:11 PM
desertstars's Avatar
Default ac controller/2001 MC SS p/n
No juice to compressor on an 01SSand have tracked the problemup to the dash controller so far. Could be loose connection or bad switch. I understand complete ac, heat, blowercontroller assemblywould need to be replaced if switch is bad. Hopefully it is merely a loose connection as the compressor was operating off and on for about a week until it stopped completely. Anyone know the Delco p/n for the complete controller in case that turns out to be the problem? have no intention of purchasing one from a dealer. Those guys should wear a mask and pack a gun. Would also help considerably if someone knows a good on-line source for the part.
Thanks.
Old Sep 12, 2008 | 08:02 PM
Nightmare!'s Avatar
Default RE: ac controller/2001 MC SS p/n
Try these sites: http://www.gmpartsdirect.com or http://www.discountacparts.com/discount_ac_parts.htm.
I recently dealt with discountscparts.com very good service and good prices. Hopefully this will help.
Good Luck!
Old Sep 12, 2008 | 10:09 PM
RickCoMatic's Avatar
car.part.com
http://car-part.com/cgi-bin/search.cgi
Old Sep 13, 2008 | 03:40 PM
Thanks to both responders. I'll check those suggestions out in case the entire unit needs replacement. Still hoping that it is a loose connection.
Old Oct 3, 2008 | 03:09 PM
Endo's Avatar
How did you trace this problem back up to the controller? Just within the last few weeks I noticed my AC doesn't work. At first I thought it just needed recharging, but I finally figured out that there is absolutely no change in temp of the air blowing when I turn the AC on or off. I was thinking the compressor is not engaging, but maybe it is a loose connection or bad switch like you say. Maybe (but I doubt it b/c I am on the driver's side) I knocked something loose when I was trying to tuck my Garmin wires up in there.
nitehawkjcb
Sep 5, 2014 09:42 AM
Frosty LS1
Apr 28, 2013 11:13 AM
Chevycarlo97
Oct 4, 2010 07:45 PM
SuperMonte8
Feb 24, 2010 08:13 PM
anarchy1974
Jul 9, 2005 08:26 AM
