5th Gen ('95-'99): abs power
Old Nov 9, 2014 | 10:07 AM
godsmknh's Avatar
Default abs power
Hi guys pulling what little hair I have, my INNOVA 3140d scannerwhich has abs abilty connects for the abs codes but just sits and says please wait retrieving after 1 hour i'm sure is enough to get info. I did check all fuses and they are good but the 1 fuse block on the driver side under the hood has a 60amp and also a 20amp this 20amp has no power on either side of the post legs should it have power ? maybe that is my problem thanks for any help
Old Nov 9, 2014 | 01:48 PM
Sorry to read that you are having a problem with your ABS
What year & model do you have ?
I hope that one of our tech's see's your post & can assist.
Good Luck on resolving your issues.
Keep checking back on your thread `OK > GOOD LUCK <
Old Nov 10, 2014 | 07:01 AM
godsmknh's Avatar
the car is 1998 3.1 base model
Old Nov 10, 2014 | 07:07 AM
Not knowing where your from (What state)... On my 1999 around 13 yrs ago I had a similar problem...turns out one of the lead wires on the rear had somehow become ripped apart...Had it replaced and has been good ever since... I would check all the ABS wiring thoroughly and you may just find its something as simple as a corroted and or rusted connection that may resolve your isse...
Hope this helps.. Keep us posted of your progress/Resolve I'm sure someone else will chime in with more tips and ideas!
Thanks for joining the MCF!
Old Nov 10, 2014 | 12:29 PM
godsmknh's Avatar
So I did some checking with the test light. I have no power going to amp fuse 20 or to the ABS relay nor do I have power to the ABS plug are there any abs power protection relay maybe under the dash, The wire that that feeds both realy and fuse also has no power
thanks for any feedback
Old Nov 11, 2014 | 04:54 PM
godsmknh's Avatar
ok guys some more trying, I did multimeter to check ohms @ all sensors, don't ask what the reading was but here goes FL- around 1600 and FR- 0 nothing at all.
RR-1060, LR-1060 and the rr is a new hub assembly. so could the RF having a 0 reading cause the no power and the 20 amp fuse? I will change the RF tomorrow thanks again for the input
Old Nov 13, 2014 | 05:02 AM
godsmknh's Avatar
as you can see this is the fuse I have no power to on either side any help? could it be the abs module bcm
Old Nov 13, 2014 | 02:29 PM
godsmknh's Avatar
ok after more poking around, every now and then i get a brake light on. also if I move the electronic brake control module around ( under the dash ) i end up with a brake light. I have no power going out of the heavy gauge wires to the abs unit under the hood. so I followed the wire all but the red lead wire goes to the plug at the control module, now I followed the red wire that is feeding the 20amp that I said I have no power so would it be a safe beat the the module under the dash is crap, and would a junk find work or reprogram need to be done..
billyjblunt79
Jan 3, 2014 11:40 AM
tbmaniacal
Nov 29, 2010 02:09 AM
Cyst3m
Sep 17, 2010 04:08 AM
jibb3r
Aug 3, 2009 05:22 PM
