6th Gen ('00-'05): ABS Harness Part Numbers
Old May 1, 2014 | 06:55 PM
Proteus157's Avatar
Default ABS Harness Part Numbers
Does anyone know the difference between part numbers 970-040 and 970-041?
The Service Traction light comes on when it rains. I'm getting the same groaning noise that others have discussed. The codes say it is the right rear wheel sensor (C1235, C1228, C1224, C1216). I checked the wire and plug, but I can't see any issues.
My plan is to replace the wire in hopes it is not the hub.
Old May 1, 2014 | 08:22 PM
03SSLE's Avatar
It looks like the 041 is a replacement for OE #10340313 and 040 replaces #10340314 or #10340316.
You have a short in the (RR) speed sensor input circuit and excessive speed variation in the (RR) sensor. Replace the RR hub assembly.
Old May 1, 2014 | 09:23 PM
Proteus157's Avatar
Got it. Thanks for saving me the time of replacing the harness.
Old Aug 18, 2016 | 11:32 AM
stillooking4bobb's Avatar
Smile 10340314
I found this wheel speed harness (10340314) on gmpartsplanet.com for $79.40. It arrived super fast in the GM packaging and solved my issue.
Mr Grizzly Mint
Sep 9, 2012 09:48 PM
red04montels
Aug 3, 2012 01:51 PM
MJClemm
Feb 4, 2012 09:58 AM
Jomao_o
Sep 21, 2011 08:21 PM
Ten32
Apr 11, 2007 10:46 PM
