96 Monte 3.4 spark plug replacement and O2 Sensor bypass
Old Feb 5, 2017 | 02:59 AM
ShaneInsane90's Avatar
Default 96 Monte 3.4 spark plug replacement and O2 Sensor bypass
Im sure there is a thread but how do you replace plugs on 96 Monte 3.4 L ..
Do i have to pull the intake.. ?
An i have removed the catalyc converter and was wondering if I should go bout by passing the O2 Sensor ... Would like to least get check engine light to go off and keep it from running to rich or to lean ..
