86 4.3 problems
Old Dec 28, 2017 | 01:24 PM
Danielc35's Avatar
Default 86 4.3 problems
The other night my car was idling high after starting and driving. I shut it off and now it don't start. I replaced the fuel pump relay and the fuel pump, still nothing. What else could it be?
Old Dec 28, 2017 | 04:36 PM
DAVESS2002's Avatar
Not that familiar with the early TBI system but as in any engine you need to check 2 things: are you getting spark and are you getting fuel. Sounds like you fixed fuel issues but if you aren't getting fuel into the engine it could be as simple as a plugged filter or else a problem with the TBI. I would check spark first, get a HEI spark tester and check for spark at the plug. On my 1987 I had to replace ignition modules a few times as they go bad after a while and won't give any spark.
Old Dec 28, 2017 | 05:49 PM
Danielc35's Avatar
Have spark. No power to fuel pump relay.
Old Dec 28, 2017 | 06:49 PM
Aerocoupe86's Avatar
Monte Of The Month -- November 2016
have you checked fuel pressure?
Old Dec 28, 2017 | 06:53 PM
user 35764368's Avatar
fuel pump run when the the key is on?
Old Dec 28, 2017 | 07:08 PM
Danielc35's Avatar
We ran power to the relay and pump kicked right on.
Old Dec 28, 2017 | 07:49 PM
Danielc35's Avatar
What powers that relay?
