7th gen a couple of problems maybe bcm?
Old Sep 26, 2017 | 04:57 PM
spcsnow's Avatar
Default 7th gen a couple of problems maybe bcm?
Im experiencing a couple of weird issues.
Im getting the following messages on the dic
1 hood open. Its not i changed the latch and tried grounding it out to no avail.
2 change battery in key fob. Put 6 different batteries in and still says the same.
3 service traction contol
4 service brake assist
5 service air bag
6 key fob only works when your 5 ft away from car
Wodering if this all coincides with the bcm.
07 monte ss 5.3
Or did the turner i have burn something out?
Any info appreciated.
Thanks Matt
Old Sep 26, 2017 | 10:45 PM
96z34man's Avatar
You probably need a new key fob. They shouldn't go bad, but they do. The $12 aftermarket ones on eBay are just fine.
Traction control and brake assist aren't related to the BCM. Can't help otherwise; hopefully wiser people can.
