3800 Intake Gasket
Old Apr 22, 2010 | 09:01 PM
nitehawkjcb's Avatar
I've reused them twice now.
Old Apr 23, 2010 | 10:57 AM
rj's Avatar
rj
(from the diagram) it doesn't seem to be that much more work to change the lower gasket once the upper parts are removed. So it might be a better idea to go ahead and change the LIM gasket while the engine is apart.
Old Apr 26, 2010 | 09:34 PM
Sliver's Avatar
I agree with what the others have said, replace the lower if you're doing the upper. I am currently in the middle of replacing my manifold gaskets due to having a stuck lifter. I could tell my gaskets were not too happy when I got them all apart. VERY IMPORTANT: Like someone else has already said- get those two plastic elbows that are part of the heating system. That is my hold up right now and I have to wait till the parts store opens up tomorrow to get them. My car would have been on the road by now had I only known about those little buggers! The whole process is time consuming, especially the first time you do it. Some bolts are in tight spaces and you have to remove an assortment of brackets that are mounted to the engine to have good access.
Old Apr 26, 2010 | 09:46 PM
seawolf18's Avatar
I was lucky that I was able to reuse those little coolant elbows. I got mine back to gether with not to much hassle, but I have taken a few FWD chevys apart before. Make sure you use a torque wrench and the correct tighting sequence when putting the upper and lower intakes back together. I believe the previous owner of mine didn't do that, and thats what caused the intake to be warped.
New2MonteNY
Apr 25, 2017 01:59 PM
Dylan313
Apr 9, 2013 10:03 PM
monte carlo 3831
May 15, 2012 09:58 PM
70monte1
Jul 7, 2010 12:13 AM
70monte1
Mar 9, 2010 05:56 PM
