2K Monte stalls when put in gear
Old Jul 13, 2015 | 06:34 PM
PtownBubba's Avatar
Default 2K Monte stalls when put in gear
My grandson's 2000 3.4 Monte runs fine, starts fine,, what it does is when at idle, and then put in reverse,, it stalls, will start again fine, they may go in reverse and go, or stall again,,,, he did not mention any dash check lights, I do have a code reader I need to put on it,,, but what are some of the 20 things that can cause a stall when shifting transmission ???
Old Jul 13, 2015 | 11:13 PM
First, I would recommend to see if the car has any active or pending codes. Next, what happens if you rev it in park?
Keep in mind, when you shift out of park and into a gear, you are now putting a load on the engine, RPMs change.
Here is a thread to review that may have some helpful maintenance things to check out:
https://montecarloforum.com/forum/fw...0-miles-46078/
Top of my head of what I would look at (assuming there are no codes):
- Check for vacuum leaks
- Clean the EGR tunnel, IAC and the throttle body
- Ensure you have a good/clean air filter
- Change plugs and wires if they have close to 100K miles, or if you have BOSCH plugs installed
Hope that helps!
Old Jul 13, 2015 | 11:36 PM
PtownBubba's Avatar
thanks for the ideas..... I just did a head gasket job on this car, so new plugs and plug wires,,new o-rings on fuel injectors,, cleaned the throttle body and air cleaner chamber,,, will check codes when and if he parks the car long enough,,,,, thanks again,,,,
Old Jul 14, 2015 | 05:26 PM
Feel free to come back and let us know what you find out. Hopefully something easy!
Old Jul 18, 2015 | 02:12 PM
PtownBubba's Avatar
Just getting car today,,, kid is busy with it,,,,,,,,,,,,,, will do some checking, a mech. friend mentioned possible torque converter lock up,,,,, possible ???
Old Jul 18, 2015 | 05:16 PM
PtownBubba's Avatar
Here is a bunch of stuff,,,,,,,,,,,,, where to start ?
Old Jul 21, 2015 | 12:25 AM
I would say start looking up each code and follow the diag chart for them. Just for grins, you may want to verify all the fuses are good. Trust me, sometimes it can be that stupid of a problem (I had one this spring).
Old Jul 21, 2015 | 03:48 AM
PtownBubba's Avatar
ok, will try that fuse check,,,, but,, after pulling up codes,,, I cleared all the codes, with my code reader,,,,, by doing that, the check engine light on dash turned off,, and I drove it around, car did not mis-behave, nor did check engine light come back on,, so issue may be intermittent,,, ,, the ABS light stayed on, as that is part 2 of the car hiccups, and not related to any engine malfunctions,,,,,,,,,,,,,,,,,,, ??? I am assuming. If it is the EGR valve,,,, is there a way to bench test that,,, by applying voltage,and seeing if it opens and closes ?
Old Aug 8, 2015 | 03:29 PM
Just wondering if there is an update on this issue.
Old Aug 8, 2015 | 04:01 PM
PtownBubba's Avatar
replace cam sensor,,,, egr valve,, and swapped out the ignition coil pack with one my mech. friend stripped from a junker,,,,, I do not like the idle,, seems rough,,, but it runs and starts fine,,,, it has been a week,,,, need to get car back and see if any codes returned,, last code was,,, intermittent missfire on #6,,,,,no other codes,,,, so changed ignition coil module,,,,,,,,,,,,,,, will have to wait on results,,,,
