2007 LT 3.5 brake light problems
I was wondering if any one knows where the brake light switch is on the 2007 models.the problems is my brake light dont come when brake is pressed but pops on and off anyhelp would be great.
Check on your metal rod connected to your brake pedal...
Your switch should be connected to it & sometimes they do get lose, & sometimes fail... When you press your brake pedal it should make contact with the switch to light up your brake lights...
Check back to see what our expert tech members post when they view your problem...Good Luck on resolving this issue...
I'm not certain, but if the side brake lights come on, I'm guessing the the 3rd brake light is powered off the same circuit. You may wanna first check if you are even getting power at the 3rd brake light connector. If so, then the 3rd brake light itself died.
Just a thought.
Just a thought.
matthew41
Jan 25, 2015 11:22 AM
hotrodharley
Nov 15, 2013 11:37 AM
heartbeat
Jan 14, 2012 10:47 PM
matrx10503
RWD Tech Guides '70-'88
Dec 29, 2011 10:33 AM
