2006 Wheel Well Liner thing?
Old Jun 8, 2011 | 11:24 AM
irulesoha's Avatar
Default 2006 Wheel Well Liner thing?
What is that called? That plastic piece in the wheel well that prevents dirt and crap from getting into the car? Mine are cracked, and desperately need to be painted. I'd rather just replacement. Google has failed me.
Old Jun 8, 2011 | 11:30 AM
06MonteSS's Avatar
painted??? the "fender liner" (that's what it's called) is black plastic...
Old Jun 8, 2011 | 11:43 AM
irulesoha's Avatar
Are they actually black? Like black black?
Mine are cracked and worn looking. More like a dark grey, and when the light hits them, they really stands out. Black car, grey wheel well, black tire. Looks awful.
Thanks though, I'll look for that Fender Liner!
Old Jun 8, 2011 | 11:49 AM
You could always try a product like Mothers Back to Black, or other Plastic products that bring back Black Coloring.
Old Jun 8, 2011 | 11:51 AM
Show All Parts Mechanical Parts Only Body Parts Only Please select a corresponding number from the illustration below to view the details of that part.1) Fender Left2) Body side Body side Left3) Insulator Either Side4) Fender liner Left5) Retainer Retainer Either Side6) Screw Screw Either Side7) Bolt Bolt Either Side8) Gm mark of excellenc Gm mark of excellenc Either Side
Old Jun 8, 2011 | 01:22 PM
JaxJim's Avatar
Like BlackSheep said - knock the major dirt off them, then hit them with the same cleaner and dressing that you use on tires. They'll look great. Of course, if they're cracked and broken, that's another matter.
Old Jun 8, 2011 | 07:35 PM
JAFO's Avatar
For aftermarket try Googleing GM1250126 for the driver side and GM1251126 for passenger side. Should be able to find them for around $15. Not as Sturdy as OE (usually) but will fill the hole.
Old Jun 8, 2011 | 07:51 PM
xxtheshockerxx's Avatar
RED DEVIL
agreed...any tire dressing will make them really black. i use water base dressing so they dont turn brown from dirt/road grime sticking to them tho
Old Jun 9, 2011 | 08:50 AM
RickAKATed10's Avatar
Photobucket
I don't see why you can't buy a new set and paint them a gloss black. Might actually look really good.
Old Jun 9, 2011 | 09:15 AM
bonang's Avatar
My rears are cracked in my 07 LS......Going to pull them out someday when it is nice and get it glued and painted black. Simple to do I had them out before. couple thin nuts and some 7or9mm bolts and there out. Gotta take the tire off to do it.
Snyderman
Aug 25, 2013 09:29 PM
sprfrk2005
Sep 16, 2011 04:27 PM
79Monteresto
May 21, 2011 05:14 AM
04MonteLS
Jun 15, 2010 03:27 PM
chevygirl
Mar 3, 2009 07:18 PM
