2006 SS sound issues
Old May 18, 2013 | 10:13 AM
JG76's Avatar
Angry 2006 SS sound issues
Hi,
I've just had a lot of service done to my '06 SS (new tires, new theft deterrent module, o/l/f, charged battery, etc.) because I've just taken it out of storage and couldn't start it because of the theft deterrent module. Anyway, as soon as I pick the car up from the dealer who serviced it, I now have a problem with the sound system. If I crank the volume all the way up, my front speakers sound okay but the rear speakers have low volume and no bass. I also noticed that the warning chimes (ding ding ding when the key is left in the ignition when opening the passenger door) and the clicks I should hear the blinker make are faint at best. Do I have a faulty power booster/rear amplifier that is mounted in the trunk, a bad/blown fuse, etc? I am not the handy type, but if anyone has any insight on if this is a quick fix, it would be appreciated. The sound was perfect prior to this service. The dealer is going to do a free diagnostic but wanted your input first.
Old May 18, 2013 | 03:57 PM
Facekicker's Avatar
The chimes come from the head unit itself so I'm guessing your fix will relate to the head unit. If you have to crank the volume all the way, it could be the amp im the trunk, although it could also be a problem with the inputs on the head unit.
I'd start there, simply by checking connections and fuses. I've pulled my stock amp so I can't recall, but I think there was a fuse on it.
Old Jun 19, 2013 | 03:29 PM
gmjunkyard's Avatar
If I had to guess, someone at the dealership cranked up the sound system and blew your amp.
fjschevyman
24
Sep 2, 2023 08:01 PM
Xavier Willis
Aug 25, 2013 09:15 AM
JG76
Jul 20, 2012 12:57 PM
Monte06NJ
Dec 18, 2008 01:57 PM
MsBeanCtr
Mar 9, 2006 03:07 PM
