2006 SS Battery No Good?
Old Jun 17, 2013 | 02:23 PM
WannaMCSS's Avatar
Default 2006 SS Battery No Good?
What does everyone think?
I turn the key, everything lights up, but just clicks.
Happened twice now, I just kept trying to turn it over and after a few times it fired up.
I noticed the radio clock also reset to 12.
And I also noticed it briefly flashed "service theft deterrent" when I turn the key.
I'm pretty positive its the GM Delco original battery.
And I have been reading on here that 6 years seems to be a time for it to go.
Sound like a dead or dying battery?
Old Jun 17, 2013 | 02:43 PM
Ya had to replace mine already and I have only 77k on my Monte. You may want to check your battery connections to insure wires are good and connections clean
Old Jun 17, 2013 | 05:41 PM
Slugger088's Avatar
Monte of the Month -- August 2013
That's a pretty long life for the original battery. May as well grab yourself a new one its time.
Old Jun 18, 2013 | 07:29 AM
WannaMCSS's Avatar
well I stopped by the GM dealer with my wife's car and picked one up only to get home and find out it is the wrong size.
The one they sold me is easily several inches too big all around.
I am surprised actually how small these batteries are, and there is absolutely no room for any larger size.
So now starts the process of returning the battery and trying to find one the right size.
Old Jun 18, 2013 | 08:28 AM
03SSLE's Avatar
Look at the label on the old battery. It should have a 'group size' printed on it. Get a battery of the same group size and it will fit. Or take the old battery with to compare with the new one.
Old Jun 18, 2013 | 08:56 AM
VictoryRedSled's Avatar
Good luck getting it out of there, its definitely a squeeze on the SS
Old Jun 18, 2013 | 11:57 AM
xxtheshockerxx's Avatar
RED DEVIL
yep sounds like you need a new one. I did mine last summer on my 07 ss. it is a squeeze for sure.
Old Jun 18, 2013 | 02:57 PM
God_Bot's Avatar
Mine went bad about four years ago! This second one is getting close to needing replaced. Winter here is hard on batteries.
Old Jun 27, 2013 | 03:18 PM
k. hales's Avatar
I have no clue whats going on with a/c delco batteries i have had 4 new batteries installed on my 06 ss since i bought it new in may of 06
Old Jun 28, 2013 | 08:05 AM
WannaMCSS's Avatar
That is starting to make sense.
After pulling my old battery out and checking the dates it was a 2009
So "assuming" its only the 2nd battery since factory.
I now installed the 3 rd battery in 7 years.
Someone suggested to me its because the batteries are so small, and the car needs so much juice that its just not a good match.
