2006 Pontiac 3.8 ?
Old Aug 10, 2016 | 12:18 PM
shawn parker's Avatar
Default 2006 Pontiac 3.8 ?
Hey guys, Any one know if this would be a simple swap for my 2003 NA ?
https://missoula.craigslist.org/pts/5724870870.html
2006 Pontiac 3.8 Liter Supercharged Engine
Complete Rebuild with Supercharger. Balanced and 20 over pistons. New pistons, gaskets, seals, rings, bearings & heads.
Contact Kory for details. Asking 2k OBO.
All opinions/advice is appreciated
Old Aug 10, 2016 | 04:18 PM
keithtaylor04's Avatar
Looks nice but to me the vlave covers seem to be switched from my 04 SS...
Old Aug 10, 2016 | 07:41 PM
talked to the guy today, nice guy, was building it to throw in a Fiero , got a bit ahead of himself and ran into a couple issues with cable actuated versus electronic, then his wife totaled her rig the other day and is selling at a loss.
I talked to a local salvage yard and also called Spalding, they both say for direct swap I need a 97 to 03
oh well, still saving up to have this engine rebuilt, same place that did the one on craigslist
Old Aug 10, 2016 | 11:27 PM
SupplySgt's Avatar
Big difference is the throttle is electronic instead of cable driven. You'll need the transmission from the donor vehicle as well. As far as interaction with the BCM, I have no idea what would go into that.
The Series III shares a lot with the Series II (the NA versions are very similar) but the M90 Eaton is a Gen V variant as opposed to the Gen III in the L67.
Aside from the electronic throttle, I would imagine that it would be similar to an L67 swap into an NA Monte. Haven't tried it, just my thoughts.
Old Aug 10, 2016 | 11:40 PM
If the right one falls in my lap I'll buy it otherwise my plan remains to have it rebuilt,
and yes trans too or might have a non moving car
at 155K it is time for some work to roll back the mileage LOL
Old Aug 11, 2016 | 02:14 PM
turbo monte's Avatar
You can use that engine no problem. All you need to do is get a throttle body adapter plate from zzp and use your factory throttle body. From there is will swap in just like a series 2 3800 would. And just use your trans and have it rebuilt so there is no wiring issues there.
Old Aug 15, 2016 | 08:26 PM
Thanks John
the guy also said has no water pump, will mine bolt on, no issues?
I don't know if he still has it, but the more I learn the better
any more info on adapter plate, or do I just tell them what I'm trying to do and they know what I need?
Old Aug 15, 2016 | 08:52 PM
he still has it,
If I know water pump is a match I think I'l grab it
Old Aug 15, 2016 | 09:45 PM
Yours would be fine I'm sure.
Old Aug 15, 2016 | 11:44 PM
SupplySgt's Avatar
I'd forgotten all about that adapter plate. Although it's fairly simple to set up a pedal for electronic throttle as well. We do it all the time in the older Camaro world with LS motor retrofits. I believe a lot of the guys actually use a pedal out of a 7th gen Monte SS or GP GXP.
