2006 Monte Struts
I know for a fact the Bilsteins are the same part number across all years 2000-07 because that's how they are advertised. However, that's Bilstein. I can't say for sure what other manufacturers' applications are. You would have to confirm through the manufacturer or possibly a supplier.
this is what I found at bilstein website. shows rear only as limited to stock on hand...
CLICK HERE FOR BILSTEIN WEBSITE
Awesome response, I knew I was in the right place when I found this site. You guys are great. I will post a pic or two after the parts are installed. I went with a 1-1/4" front sway bar and poly bushing and a new rear bar as well. SSC springs and KYB AGX adjustables
Nice info guys, I did order from Canuck so it must have been your post that I saw. So far my only concern with the KYB AGX shocks is most sites distinguish a difference between 05 and 06 shocks a being different but this site (CLICK HERE) shows 2000-2006 as the same shock. I hope their cataloging is right because I ordered today.
I had KYB AGX struts paired with the Eibach (Pro-Kit) lowering springs on my 2003 Monte Carlo SS (installed early 2007) and that was a pretty decent ride and setup in the four years I ran it on that car. Although, Eibachs advertised drop was about 0.5" less than the Canucks is so I'll be interested in how the ride is putting Canucks with the AGX.
Maybe this is what we will be doing on our next suspension overhaul....
this is pretty aggressive procedure but I commend the guy for going for it on his Grand Prix.
RADICAL KONI COILOVER BUILD
