2006 MC SS : Radio and dash light wont shut off after opening the doors
Old Aug 11, 2023 | 03:24 PM
Slugger088's Avatar
Monte of the Month -- August 2013
Default 2006 MC SS : Radio and dash light wont shut off after opening the doors
Hello all:
It's been quite some time since I posted. I am hoping someone may have the answers for this problem on my 2006 SS. So when all things are operating correctly, when I take the key out of the ignition and sit in the car, the normal thing is the radio will continue to play for about 10 minutes and if I decide to open the drivers door before that it should instantly shut off the radio and dash lights power.
However, this is not happening. When I open the door the radio and dash lights will remain on. They do eventually go off after 10 minutes after I have left the car. Anyone have any clue? Is it BCM, a door jamb switch?
Thanks guys
Old Aug 14, 2023 | 03:13 PM
Does the car seem to recognize the drivers door being open at all (ie does the dome light come on when you open it)? Id strongly suspect the door switch first, but certainly should test it to be sure. I had the drivers door switch fail on our 08 Impala.
Old Aug 14, 2023 | 10:37 PM
Kawiksolo's Avatar
Hey,
If your 2006 SS has radio and dash lights staying on after opening the door consider checking the door jamb switch, BCM and wiring. For expert help visit a car detailing specialist in Alexandria. Learn more at the Car Detailing Alexandria website. Good luck..
Old Aug 14, 2023 | 10:38 PM
Kawiksolo's Avatar
Hey,
If your 2006 SS has radio and dash lights staying on after opening the door, consider checking the door jamb switch, BCM, and wiring. For expert help, visit a car detailing specialist in Alexandria. Learn more at the Car Detailing Alexandria website. Good luck..
Old Aug 15, 2023 | 04:15 AM
Kawiksolo's Avatar
Professional auto detailing services allows the car to optimally use the dryer time by reading the time left on the countdown timer. Perfect Auto detail Shining ensures the greater efficiency of vehicles to get them ready for optimal start dryer time. visit url https://aperfectshinedetailing.com/c...ckville-md.php
Old Aug 15, 2023 | 08:23 AM
Originally Posted by Kawiksolo
Auto Car Detailers Car Wash. Our skilled team pampers your vehicle inside and out, with meticulous hand washing, paint rejuvenation, and interior magic. From sleek exterior to pristine interior, we make your car shine........ https://autodetailersofalexandria.com/
You missed a spot.
Old Aug 15, 2023 | 09:29 AM
Kawiksolo's Avatar
Old Aug 18, 2023 | 12:06 AM
Slugger088's Avatar
Bumpin96, The dome light does not come on when I open it.
I am pretty sure if I open the passenger door it does come on. But ill check again.
Old Aug 18, 2023 | 08:36 AM
Sounds exactly like the door switch issue we had on our Impala then. Certainly could be something else, so its worth testing before replacing, but Id bet the switch failed.
Old Aug 24, 2023 | 11:58 AM
Slugger088's Avatar
Thanks ill get around to it on Friday and let you know.
