2006 LT -> No heat at idle
Hi guys,
Wondering if you can help me out. I bought a gorgeous '06 LT with the 3.5 for my wife last month. Only has 103,000kms on it. Having trouble with the cooling system. When it's stopped at a light or otherwise idling, the heater goes cold. I tested it in the driveway, and if she's sitting at 1k, there's no heat; if I increase the RPM's up to 1500, the heat comes back. I've taken it back to the dealer, and they supposedly fixed it (air trapped in the system or something), and it was working fine. However, it's started to do it again. Any advice? I love the car, but I am getting frustrated that we're having problems with a car that we've only had for a month.
Any help would be greatly appreciated!
Thanks
Adam
Thanks
Adam
I have a friend who's 3.4 was doing the same thing and, after replacing the water pump, radiator, thermostat and flushing the cooling system for air bubbles, it turned out to be a head gasket. You may want to check your engine's compression to check for vac leaks.
Hi guys,
Thanks
Adam
Thanks
Adam
It's odd because the method of bleeding your car is much different than just opening a valve. Usually takes 3 or more attempts of adding coolant, running the car, adding more, running the car.
Anyone that didn't suggest a partially plugged heater core should leave the tools in the box and give up on their attempt to be helpful. Have the heater core flushed out with a mild solvent and warm water. It will be good as new. That is 100% classic plugged heater core symptom.
7th Gen ('06-'07): 2006 MC 3.5L V6 idle issues and loss of power at speed
ckempfer
Aug 8, 2014 03:46 AM
