2005 Monte Carlo heater ac problems
Old Feb 16, 2011 | 07:54 PM
Chevygirl25's Avatar
Default 2005 Monte Carlo heater ac problems
Does anyone know what could be wrong with an 2005 Monte Carlo. When the heater or ac is turned on and sometimes nothing comes out. When I turn the switch on I can hear a click noise but sometimes the heater or ac won't blow into the car.
Old Feb 20, 2011 | 07:13 AM
99inprogress's Avatar
sounds like possibly a bad blower motor. before you spend the $$ to replace it, check the wiring and the fuses, you said it clicks- that could be the sound of a short or a fuse popping, check your wires, take out and inspect/clean your fuse and replace the fuse if broken. or it could be a fan switch either bad or the wiring harness has shaken loose or something. keep us updated.
JamieHale86
Feb 8, 2011 08:41 PM
sunshine1979
Oct 28, 2010 06:50 AM
jdawgkemp
Mar 26, 2009 01:00 AM
06 Monte LT
Jan 5, 2009 02:56 PM
ehunni7989
Dec 10, 2008 03:39 PM
