2004 Monte Carlo SS idles wierd in drive
Old Jan 25, 2014 | 09:49 AM
vikesfan's Avatar
Originally Posted by Firebird14
I already tried using a stethoscope to no avail. The noise was too difficult to track down that way.
Can anyone confirm if the lower engine mount on these cars can be worn out enough to cause noise/vibration without any visible signs of wear (cracking/separation of rubber)?
yes, the rubber can seperate from the metal which is undetectable while its on the car. you can try to "test" it by slightly jacking up the engine (use a piece of wood on the jack to push on the oil pan). dont over do it, you dont want to go to far and actually break it when it wasnt broken
when you jack it up slighty, the car should want to go up with the jack, but if you shine a flashlight onto the mount, and you can see any space in between where the rubber meets the metal, then its toast.
the mount on the passenger side isnt difficult to remove, just difficult to "get to". its just 5 bolts, 2 on the front near a/c compressor, and 3 on the back down by where the transmission connector bracket is.
then you have the 2 bolts under the car and in the aluminum cradle.
you will have to jack up that side of the engine about 3" to remove the old part.
kera356
Dec 1, 2013 05:07 PM
YelloJac
Oct 14, 2012 11:37 PM
powerguy5051
Feb 24, 2012 06:56 PM
dylan_dude2005
Aug 16, 2009 11:43 PM
nomad59
Dec 20, 2006 06:24 AM
