2004 Monte Carlo RR Defog
Old Dec 24, 2008 | 10:21 AM
indytruder's Avatar
Default 2004 Monte Carlo RR Defog
Brand New Member!!!
My 2004 Monte Carlo LS RR defogger does not clear the window and appears to shut off while the Defog light is on. Has anyone else experienced this and fixed the problem? The fog is removed in the center of the window near the wires; the rest of the window does not clear. Then the whole window fogs up with the Defog light still illuminated on the button.
Ed
Old Dec 24, 2008 | 11:07 AM
Default RE: 2004 Monte Carlo RR Defog
Hi `Ed from Nobleville, Ind & Welcome to the
Monte Carlo Family Forum.
Theres a possibility that you have a connection break in the lines on the rearwindow. Normally when this happens you will have some of them (the lines) work, but not all of them. This can happen when
the rear window is being cleaned, and the connection is bumped
and broken.
Suggest checking your contact on rear window for breaks.
I know there is a tester for power current in the electronic line,
but I dont know the name of the tester.
Check back later, & hopefully one of our Expert Member
Techs will have a answer for you.
Wish you Good Luck on repairs, & a
Happy Holidays to you.
`Space
Old Dec 24, 2008 | 11:20 AM
Hi Ed,
The most likley cause is a break in the electrical pathways of the defroster. The lines you see on your window are actually conductive lines of material designed to carry the current across your glass causing it to heat and subsequently defrost your window. The most common problem is a break in one of those lines. Check all fuses. The fix is to go to your local auto parts chain ad buy some conductive defroster touch up paint.
Below are some link infor -Good Luck-
Rear Window Defroster Fix - Car Repair - Popular Mechanics
More im-portant, you need to give the conductive paint or adhesive a clean surface to stick to. ... Don’t touch the surface or you’ll leave fingerprints. ... The blower defroster waits for the engine to warm up and send hot air through ...
www.popularmechanics.com/automotive/how_to/42212... - 70k - Similar pages
http://www.popularmechanics.com/auto...o/4221212.html
Repairing Your Rear-Window Defroster - Popular Mec...
But the rear-window defroster clears only a narrow strip near the top and bottom of the ... grid lines is as simple as masking them and using a special conductive paint. ... If your window has a defroster grid, the only thing that should ever touch the glass is a soft ... myBuild: Sign Up for PM’s DIY Community! ...
www.popularmechanics.com/how_to_central/a... - 39k - Similar pages
[ More results from www.popularmechanics.com ]
http://www.popularmechanics.com/how_...e/1272291.html[/align]Method to fix joystick buttons - rear window defroster repai...
I picked up a bottle of rear window defroster repair "paint" at an auto parts store. (They may have it at Walmart - but I've never ... It is electrically conductive. ... Slightest touch on a button and contact is made. ...
www.atariage.com/forums/index.php?showtopic=1144... - 71k - Similar pages
http://www.atariage.com/forums/index...owtopic=114461
DIY: Repairing Your Rear Window Defroster
If you ever painted window trim you know it doesn't take much to scrape paint off glass. ... The only thing that should touch the window glass and defroster grid is ... electrically conductive epoxy to glue the defroster terminals back on. ... in a garage that is heated and the whole car warmed up to above 65° F. ...
autorepair.about.com/cs/doityourself/a/aa112302a... - 27k - Similar pages
shovelhead pete
Mar 15, 2015 09:02 AM
USMCdevildog
Dec 17, 2010 09:05 AM
montecarlo48178
Oct 9, 2010 03:31 PM
5207234w
Feb 23, 2009 11:07 PM
Nightmare!
Oct 31, 2007 06:59 PM
