2003 SS Wont Start! Cranks over but wont fire up. Help please!
Went to start up my 03 SS Monte this morning and cranked over but wouldnt fire up no matter what. Had this car for two years and havent had any problems. I sprayed some starting fluid in there, nothing... I checked for spark from the wires, nothin...I also checked all the fuses. Im not familiar with all this electrical stuff on this car any information would be great! I just need somewhere to begin!
I would suspect crank sensor because the ignition module and coils are pretty reliable on 3800's. Is the engine light on when you turn the key to run? If not the PCM could be toast but I'd get a tech at a good garage to scope the crank signal the wires from the crank sensor go direct to the PCM which is inside the stock air filter casing so it's easy to test there.
I pulled the ICM out and brought it down and had it tested and it passed everytime. All the coils are good as well. The engine light does come on when I try and start it. I was told the PCM's rarely go out so im guessing my next thing is the crank sensors like you suggested. That would require me to have the car towed to a mechanic shop right?
No. Just buy a 3800 harmonic balancer/crank pulley puller off ebay. I got one for like 30 bucks. Remove serpentine belt. Remove crank pulley. Remove crank sensor, replace crank sensor, reassemble. Took me like an hour, and I was bull****tin.
You don't need to remove the harmonic ballancer to replace the crank sensor. Have the PCM checked for codes. If it has a crank sensor code 2 scenarios could play out 1: the sensor could be bad. 2: it may have a small amount of rust pushing the sensor away from the crank shaft and it isn't getting a strong enough reading. Even if there isn't a code I've seen the rust thing do that. Make sure the location that the sensor goes into is clean metal on the block but only use a scraper or razor blade, don't use any type of grinder.
Same problem no spark to plugs need help bout to give up
