2003 SS knocking sound
Old Jul 23, 2015 | 03:15 PM
Charleslatrelle's Avatar
Default 2003 SS knocking sound
Hey I have a 2003 monte carlo ss and I've noticed a ticking or knocking sound it doesn't do it wen first started but after car has been driven and warmed up has anybody had this problem and any advice would be helpful it had 126000 miles
Old Jul 23, 2015 | 03:27 PM
How long has it been since you changed your oil? Could be thinned out oil or lifter ticking. A ticking could also be an exhaust manifold gasket leak.
I am sure there are other causes and others will give some ideas.
Does the ticking increase or decrease with RPM's of engine or does it stay the same?
Old Jul 23, 2015 | 03:30 PM
It's been a couple months since oil change I keep up with that it hasn't been 3000 miles since last oil change and it does increase with RPM's
Old Jul 23, 2015 | 03:54 PM
Have you gotten your ear close to the engine to try to hear in which area it is loudest (front, back, right, left)?
I am sure others will respond also but my guess would be exhaust manifold gasket leak.
Old Jul 23, 2015 | 03:58 PM
I tried but I couldn't really tell
Old Jul 23, 2015 | 04:12 PM
Yeah sometimes it is really difficult to tell where a noise is coming from. I guess you could wait until it was dark out and then start your car. As it warms up/once it's warm and still running, use a flashlight to see if you have any exhaust coming from around the gaskets. While you are at it with the flashlight, you may also want to look under your car near your down pipe for any escaping exhaust.
Old Jul 23, 2015 | 04:29 PM
I'll give it a try thanks
iMuf
Oct 12, 2013 12:09 AM
Xavier Willis
Aug 25, 2013 09:15 AM
michael2938
Jan 16, 2007 02:34 AM
clayg80
May 4, 2005 11:10 AM
