2003 monte carlo 3400 starter signal intermitant
Old Jun 12, 2008 | 11:12 AM
makonkey's Avatar
Default 2003 monte carlo 3400 starter signal intermitant
Hey I have a 2003 Monte Carlo with the 3400 v6. I pulled my engine and had the heads replaced since the rocker arm bolts stripped out. I have had the engine back in for a while and it sometimes has trouble starting. When I turn the key it just clicks. I replaced the battery and the starter. It still will not work at random times. I have descovered that if I tap the signal post on the starter with the positive linked with a jumper cable it comes right on. I am pretty sure the problem is somewhere between the ignition switch and the starter signal post. I just do not know what to check or what wires to trace. Any help would be great.
rmorman
Oct 24, 2013 06:32 PM
Hognutsdeluxe
Sep 30, 2013 07:47 AM
Ron A
Jan 29, 2012 10:28 AM
kicker
Jun 3, 2010 10:39 AM
kc2kth
Mar 30, 2010 07:46 PM
