2002 multi function switch
Old Aug 18, 2009 | 09:53 AM
ohsuzanna's Avatar
Default 2002 multi function switch
i have a problem with the multi function switch on my 2002 monte carlo. i was driving along and my high beams stuck on and head lights went off. turned off car and high beams stay on!!! called gmc about a recall because they want 520.00 dollars for part!!!!! extreamly dangerous and this should be a recall, they told me they had no other complaints, i cant bealive that!!! Anyone else had this problem?
Old Aug 18, 2009 | 08:27 PM
jim fischer's Avatar
yup, with my 05. i would turn on the hi's and they would stick, (sorry to whom ive blinded!!) but after on/off a couple of times they would go off. took it to the dealer and they installed a new one, and they did say i wasnt the only one w/this problem. i think you are stuck paying the 520.
Old Aug 19, 2009 | 04:47 AM
JAFO's Avatar
My 03 is somewhat the same. The feel when I try to put the high beams on is different than I'm used to and a couple of days this week when coming into work, I went to switch off the high beams it also cut off the lows, was driving with only the fogs and parking lights, a quick panic pull or two on the switch turned the lows back on. Only had the car for a little more then a month so I'm still feeling out what should be normal and what isn't... that obviously isn't normal!, Usually don't use high beams so I think I'll just quit, now that I hear your stories and hope the deer see me and don't decide to challenge me to a race. Don't have the $500 to spend right now and don't need to pi$$off some country bumpkin with a loaded 12 guage in his back window!
monteride
Sep 2, 2013 06:03 PM
Jomao_o
Nov 26, 2012 06:22 PM
muleys99
Jan 15, 2011 09:43 AM
98Z34
FWD Tech Guides '95-'07
Sep 27, 2010 10:27 AM
artlawton
Apr 15, 2010 08:23 AM
