6th Gen ('00-'05): 2002 Monte Carlo SS Dale Earnheart 3.8
Old Jan 2, 2022 | 01:02 PM
  #51
Carloman61's Avatar
Very true! I've done just about everything except a fuel pressure test. I'm thinking since car sat for a few years and gas I took out was kinda Orange.
Im thinking maybe the engine is cutting out a bit due to fuel pump sock being gummed up.
I still have to put in the 02 sensors I bought
If pump turns out to be good and I put sensors in
And still not good. I'll be creating some very choice words!
I won't give up but still.
im crossing my fingers here..
Old Jan 2, 2022 | 03:20 PM
  #52
Carloman61's Avatar
update.. Did fuel pressure test and key on. No start pressure is at 50 when I start car it drops to 47 steady
When it's running and I unplugged vacumm to FPR it jumps up to 55 psi
So looks like fuel pump is ok
Next step is O2 sensors.
I'll update after
Old Jan 7, 2022 | 10:17 PM
  #53
Carloman61's Avatar
Well here I am again!
same old crap! I keep getting the PO304 code but Everytime I run it. The code comes up less and less
I put risolan ring seat in oil and a bottle of risolan detergent additive in and seems like it's working
I have less lifter noise and seems like rings are sealing good!.
I pulled the number 4 spark plug and it actually has a grey burn on it as it should!
To recap. First time I pulled the plugs all where burning light grey but number 4 cylinder was little wet probably fuel! Replacing the injectors was a good idea.
Now it's doing better
when I keep engine at around 1200 rpm's check engine light stays off and lifter noise disappears
Im hoping the more I run it the better it gets
Old Jan 10, 2022 | 11:21 PM
  #54
Carloman61's Avatar
Update! I've been running engine every day and I pulled #4 plug. It's burning a light grey as it should and engine sounds better,!
i ordered a new fuel pump that comes with new sediment sock!
I will change that!
I have made checks on all sensors and they ar all within specs!
So I think with new fuel pump and pre filter
This car will be like new condition running wise!
So far I have put over 300.00 in so far.
Why stop now!
Old Jan 11, 2022 | 09:06 PM
  #55
Good to hear things are better. I hope that new pump puts this all to rest for you.
Old Jan 11, 2022 | 10:12 PM
  #56
Carloman61's Avatar
Thanks I'm going to get put Thursday and install it.
ill post the results
  #57
Carloman61's Avatar
Old Jan 12, 2022 | 10:18 PM
  #58
Angry
Awesome, hope it delivers the results you are wanting. Don't mind me, I'm getting my lounge chair and popcorn ready... Best of luck, fingers crossed for you bud!
Old Apr 3, 2022 | 03:55 PM
  #59
Carloman61's Avatar
Default Fuel pump
Ok replaced fuel pump sock filter
and now car drives ok but still a little hesitation when higher rpms I drove it 6 miles round trip and it drove better than before. More power..
I still get PO304 coming up and some lifter noise from back of engine possible cylinder 4
I'm thinking that's why the misfire..
After I changed oil again I added some restore the blue stuff in can it says for engine compression
I'll drive it some more and see if it works.
drivernumber3
Nov 26, 2021 11:51 PM
Jasonwilburn98
Jul 20, 2018 11:21 PM
mikeymoe
Jan 5, 2016 04:47 PM
02MonteCarloSS1
Oct 31, 2015 04:54 PM
Nawxgh
May 7, 2012 02:33 AM
