Opinion Needed: 2002 Monte Carlo SS 3.8
Old Apr 22, 2017 | 08:09 PM
Bgdee7's Avatar
Default 2002 Monte Carlo SS 3.8
I have a problem when I pump gas, it's leaks/drips from directly under where u pump the gas from a small black box, any thoughts or has anyone had this problem?????????
Old Apr 23, 2017 | 02:09 PM
Imp42017's Avatar
That sounds like your EVAP Charcoal Canister. Does your car have a CEL or anything that is showing an error?
You sure it is leaking from that area and not just running down something landing on that and then makes it look like it is coming form there?
James
Old Apr 25, 2017 | 06:58 AM
Bgdee7's Avatar
Default 2000 mc ss
James
No error showing it only leaks when you pump the gas, someone said I could be a filter but there is no error. The car sat for at least 4 to 5 years I fixed everything just can't solve this small problem.
