6th Gen ('00-'05): 2002 Monte Carlo Hard Shifting
Old Jul 18, 2016 | 10:33 AM
tttiimmyyyd's Avatar
Default Same issues
I am having the same issues i am getting an 02 sensor code aftet ive replaced both sensors with acdelco oem sensors. Car shifts hard in stop and go traffic but if i clear the code and readiness monitors it seems to go away for a little while and then the code comes back along with the hard shifting.
Old Oct 17, 2016 | 11:05 AM
codyswanson4's Avatar
Originally Posted by Jaymonte06
I have the exact same issue with my 06 you explained my problem to a T. If you figure anything out or fix the problem let me know please
Check out your engine mounts (there are 2 dogbone style mounts on the top and 2 on the bottom) for cracking and degradation. In mine, the 2 on the bottom were still from the factory, so they were really bad and allowed the motor to move much more than it should. My theory is that this is what I'm feeling, but I haven't replaced the bottom mounts yet. I'll update when I do, though.
Old Oct 17, 2016 | 11:17 AM
Yeah i ended up narrowing it down to the cat converter and secondary air injection system
I will take a look at those engine mounts tho
Old Apr 6, 2019 | 12:16 PM
Carlo.SS's Avatar
I literally have the same exact issue. After reading all of this, I will try ALL of the suggestions mentioned above. My 01 SS already has the new Cats, but I will change out the o2 sensors and (PCS) and (TPS) and the motor mounts. Thanks for everyone's information. Have a great day. Also, I will try to keep everyone posted via Update.
BGraham10
May 8, 2016 06:40 PM
koltman889
Mar 21, 2016 08:16 PM
Viejo30
Dec 23, 2014 03:26 PM
godsmknh
Nov 9, 2014 01:50 PM
mavrickf1613
Apr 9, 2009 09:12 PM
