2002 monte carlo engine swap?
why not do a top swap or swap out for an L67, you could bite the bullet and just go all the way for the 5.3L swap which will be a ton of work.
200k miles isn't a ton for those 3800 series II's I could see you doing a top swap, check some of the bottom end make sure everythings good with the current engine.
The lower compression will make you some more power than just an L67
I also know the FULL history of my car, and have a 2nd car because there will most likely be plenty of down time while I break stuff lol
true, how many miles on your car?
