2001 Monte rear defrogger problem!
Old Jan 12, 2009 | 02:49 AM
rgant_19's Avatar
Default 2001 Monte rear defrogger problem!
I am having is with the rear defrogger, the little piece thatson thedriver side (on therear window), that little piece that's attach to the window. Well, that little piece has came off. I now have to prop something (like a wedge) to position the piece so it will work when I turn it on from the front. Any suggestions about that on how can it be repaired? From what I am seeing, it seems like it needs to be soldered back onto the window!
Old Jan 12, 2009 | 05:07 AM
bowtietech's Avatar
Default RE: 2001 Monte rear defrogger problem!
The rear defogger terminal contact can be reattached to the defogger grid using silver solder. Here is the procedure.....
[hr]
[/align][/align]
[align=left][align=left]
Repair Information for Reconnection of Rear Window Defroster Contact or Tab[/align][align=left]
Models:
2000-2009 GM Passenger Cars and Trucks (including Saturn)[/align][align=left]
with Electric Rear Window Defroster (RPO C49)[/align]
[hr]
This bulletin is being revised to update the applicable model years. Please discard Corporate Bulletin Number03-08-48-006D (Section 08 - Body and Accessories).
[hr]
Repair Suggestions
Soldering Defroster Contact Tabs
In most applications it is preferable to create a new solder connection to reattach a separated rear defroster tab. If you take note of the steps below, it is possible to create a new solder joint that is equal to, or stronger than, the original. The generic procedure below is not very time intensive, but does include minor preparation work to create a good bonding surface. Be sure to follow each of the steps as combined they will produce the strongest bond possible. Please consider the following before attempting the repair:[align=left]
Soldering introduces significant heat to the glass window of the vehicle. When performing the re-connection of the tab, use only the heat required to do the job. Pre-Heat the soldering iron, have the solder in your other hand ready to go the moment you have enough heat to melt the solder.[/align][align=left]
If it is winter; bring the vehicle into the service garage and remove any snow from the back window area. Allow time for the glass to warm to the temperature inside the building. Soldering creates a "hot spot" in the glass. DO NOT solder on cold glass.[/align][align=left]
Caution:Heating the glass excessively, or repeatedly without time to cool, may result in glass breakage. ALWAYS wear safety glasses when performing this repair! [/align][/color]
[align=left]
You must use a Silver-Bearing Solder to make the connection. DO NOT attempt this repair with conventional Lead / Tin solders. Silver Bearing Solder will adhere to the electrical buss bar making a strong and lasting repair.[/align][align=left]
Protect surfaces under the area to be soldered. It is very easy to drip solder when performing this repair. Just placing a shop towel under the soldering area is sufficient protection.[/align][ol][/ol]
Soldering Procedure
[ol]In many cases the terminal tab will still be in the connector when you examine the vehicle. For Chevrolet Tahoe, Suburban, GMC Yukon, and Cadillac Escalade vehicles (with moveable glass), always replace the defroster tab (GMP/N25916031). For all other vehicles, please reconnect the original defroster tab.
Important:DO NOT re-use the existing defroster tab on new style utility (GMT900) vehicles with moveable glass.
Prepare the surface of the used defroster tab (Not required for new tabs on new style utility models (GMT 900) and the defroster buss bar with fine grain (500 grit) sandpaper or Emery cloth. It is not necessary to remove all of the original solder but it should be scuffed sufficiently so that no oxidation is present. The photo above shows a close up of a properly prepared surface.
Tip
You may want to mask the glass around the contact area with tape. This is easy to do and will allow you to safely prepare the contact surface without the risk of scratching the glass or the black painted shading.
Important:Most rear glass has a black painted masking around the edge of the glass. When cleaning up the connection surface be very careful not to damage the surface of the black shading or the surface of the glass.
Wipe the newly prepared contact area with Kent Automotive Acrysol (or equivalent) to remove any residual oil or dirt.
Important:You must use a Silver-Bearing Solder to make the solder joint. DO NOT attempt this repair with conventional Lead / Tin solders. Most suppliers have this type of solder available, and it is available nationally at Radio Shack. It is sold in several diameters and either are acceptable for this repair.
For this step, it is permitted that two technicians be used if required. Heat the new contact on the surface of the buss bar that is to be soldered. Long nose pliers are suggested to hold the contact in place. Keep the solder ready and begin flowing out the solder as soon as the melting temperature has been reached.
Tip
If a single technician is attempting this repair, it is sometimes beneficial to wrap one turn of the solder around the new contacts base. In this manner as the melting point of the solder is reached, a layer is deposited on the bottom side of the contact.
[color=brown]Important:Try to align the new contact so that it is positioned with the same attitude as the original contact.
The photo above pictures an ideal finished solder joint. Additional stray solder will not harm the performance of the bond however, while it is unlikely that customers may refer to the appearance of the rear window defroster and its components as a positive styling feature of the vehicle interior, it is easy to elicit the opposite reaction due to a poor cosmetic application.
Remove and replace the rear defogger electrical power connector by crimping a new connector to the feed wire. The proper connector can be found in the Packard Electrical Assortment, Tray 18, Position 5. The connector is P/N12034110.
Apply a small amount of GM Vehicle Care Dielectric Lubricant to the rear defogger connector.
Connect the electrical connector to the defroster tab. Be sure to fully engage the connector. An improperly seated connector may cause excessive resistance and hamper proper operation of the defroster. [/ol]
Parts Information
Acrysol can be ordered directly from Kent Automotive at 1-800-654-6333 (in Canada, 1-800-563-1717).
Radio Shack products can be found nationally at retail locations, www.radioshack.com, or at 1-800-843-7422.
In Canada, use The Source by Circuit City www.thesourcecc.ca or 1-866-454-4426 (English) or 1-866-544-4431 (French).
The balance of the parts list can be ordered through GMSPO.
Part Number
Description
25916031
Tab, Defroster Power (new style utility models (GMT900))
12034110 (Tray 18, Position 5)
Rear Defroster Electrical Power Connector (Packard Electrical Assortment Only)
64-013E
Radio Shack Silver Solder (0.22dia)
64-026E
Radio Shack Silver Solder (0.62dia)
P20005
Kent Automotive Acrysol Solvent (32fl.oz.) 946ml
12377900 (U.S.)
10953529 (Canada)
GM Vehicle Care Dielectric Lubricant (2fl.oz.)[/align][/align].............
Old Jan 18, 2009 | 11:07 PM
rgant_19's Avatar
I appreciate "bowtietech", man I knew it was a simple task. Here's how it looks inside my monte:
I was trying to hold it in place witha cotton ball or something just for temporary (since I do live in chicago LOL). The weather here is a hassle but I know how to maintain it. Is this procedure you have blessed me with is a DIY? If so, I will try it but if not I will have to go to the dealer to get it done because I really need that fix. Do you think by me apply tints on the rear window will cause it to malfunction even more?
[IMG]local://upfiles/3983/5F05CCC1B5714416AEE34741BD687F80.jpg[/IMG]
Old Sep 8, 2009 | 09:07 PM
Vegas67's Avatar
Default rear defroster issue
Whats goin on all, I just got my monte the other day- a 2001 SS with 89000 on it for a steal in my opinion. I traded in an 05 Scion XB and actually lowered my payments, Insurance and payoff amount.. Thats a sweet deal to me, this beauty looks like new.
So I have two issues first, drivers side defroster was popped off, I soldered it back on, it seems like there may be a little to much resistance still in the connection I made, is this going to be an issue?
second, driver side heated seat not working, whats the solution on that one.
MJClemm
Oct 9, 2022 09:13 AM
Frosty LS1
Apr 28, 2013 11:13 AM
Joester16
Jan 6, 2013 05:53 PM
rjmfa
Dec 22, 2012 12:17 AM
IhatemySS
Sep 26, 2008 06:17 PM
