2001 MC problems
Hey guys,
Got the hard starting fixed - changed the fuel filter but a few more problem arose, my low coolant light keep turning on and off and it's driving me nuts I also noticed that its smells a bit like coolant around the car but no leaks are apart coming from the rad, maybe a flush is needed? Also can I put any old coolant in or does it have to be a special kind ? O
There also seems to be a ticking coming from my alternator area only hear it when the belt is turning on the car...
Also where is the coolant sensor located on the tank itself?
Much appreciated
- victory
Much appreciated
- victory
Hey guys,
- victory
- victory
AAAaacctuually... First I'd check the weep hole on the water pump. I have the same year MC, therefore: 4_zps44ec41ba.jpg
I had the same problem. Intermittent coolant level warning lights, faint coolant smell, water pump bearing ticking away as its weep hole shed tears of precious antifreeze. What you're lookin' for is a coolant trail runnin' down the side of your water pump. Might be faint, might not... depends on how long that leaks been seepin'. Grab yourself a good flashlight. I'd suggest runnin'er warm before you start lookin' as well. Lookin for a reflection from liquid is easier to spot then dry buildup.
If it's not your water pump, (which I'm honestly betting it is...) then It's time to check around the throttle body. Again with a good flash light, look for any fluid around the TB, or any gaps in the seam.
Marked also is the location of the coolant temp sensor, which is also worth checking for leaks, while you're there lookin' anyway.
If not there, time to check your dipstick for any coolant in the oil.
Also, no... not any ol' coolant can ya toss in. Dexcool. Some may argue the point, but manufacture recommends, and horror stories abound of people blowin' such advice 4 sheets to the wind and winding up with costly repair bills their only reward for their courage.
The sensor is right under the radiator cap on the radiator. You can just unclip it and the light will stay off if you want.
Dexcool can get a little gunked up and cause the sensor to trip. You definitely should get a good flush though.
I threw a great big bottle of random coolant to make sure it has plenty, I will check on the water pump tomorrow sounds like it could be it , I already checked the oil it's fine , in fact it was just changed..
the coolant sensors will get stuck inside sometimes, if you take an extension, and give it a "technical tap" the light may go off otherwise, you should replace it. wouldn't recommend unplugging it. its kinda an important sensor, ya know.
it was a 50/50 mixture - the green ****. I'm not to worried, the leak seems to be coming from the holding tank, I filled it up to pretty much to the top to be a smart *** and the rubber house was covered in green coolant, now I just have to get a new rad support on it, mine rotted out from the bottom, do you know if they need to be welded or are they just bolted on?
- Victory
- Victory
and I quote myself here.. "Also, no... not any ol' coolant can ya toss in. Dexcool. Some may argue the point, but manufacture recommends, and horror stories abound of people blowin' such advice 4 sheets to the wind and winding up with costly repair bills their only reward for their courage."
Meaning, these cars REQUIRE Dexcool.
Dex-Cool (ethylene glycol) is identical to the Chrysler & General Motors factory fill. Havoline had the original patent on Dex-Cool and manufactures it for GM. The benefits of Dex-Cool are:
Respect the carlo. Salude! o7
- Lower alkalinity
- Contains NO silicates, resulting in longer lasting water pump and engine seals; longer shelf life.
- It is Nitrite-, borate-, phosphate-, nitrate- and amine-free.
- 100% biodegradable in its pure unused condition.
- Longer lasting (Dex-Cool has been shown to remain above 95% of its original concentration after 150,000 miles in automobiles)
Mixing the "green stuff" with dexcool can cause major problems. It could make your current coolant turn into gunk. I would recommend getting a full flush and refill. Also if your still losing coolant it could be the start of a head gasket or intake gasket leak.
I use the cheap stuff... The one that mixes with all brands....
50/50 mix is a waste of money! Your paying full price for half antifreeze half water.... I prefer to buy full strength and mix it myself... I have antifreeze tester.. That way I know its mixed properly!
