2001 Major Electrical / TC Problems
Old Jun 19, 2006 | 03:40 AM
oldnumber7's Avatar
Default 2001 Major Electrical / TC Problems
Car is 2001 3.8L
Current Problem:
-Abs / Traction control goes crazy when turning corners and at low speed
-Radio says "Locked" and does not work most of the time, sometimes it works fine then later goes locked
-Air Conditioner only works when Radio does not say "Locked"
-Battery gauge does not register any voltage when radio says "Locked"
Warning Icons Displayed:
-Service Traction Control
-Battery Warning (when radio "locked")
-Service Anti-Theft system (when radio "locked")
Warning Lights Displayed:
-ABS
I have no idea what is wrong with this car but it appears to be possessed! One out of five times it will be perfectly fine except for the traction control problem which occurs almost 100% of the time. The only time the traction control does not act up is when the car is in its "locked" mode. Note that the car has never failed to start except for today when I turned the key and nothing happened. I tried again 5 seconds later and it started no problem.
Old Jun 19, 2006 | 06:23 AM
mickey's Avatar
Default RE: 2001 Major Electrical / TC Problems
sounds to me like you have a guage pod going nuts on you or out.
As far as the radio it is all connected. but have you tryied to call a dealer and find out what they say?
Old Jun 19, 2006 | 10:31 PM
montejass's Avatar
I would run it by an AutoZone or similar parts house that can pull codes on it.
Generally they will do it for free and be able to point you in the right direction..
Old Jul 6, 2006 | 09:22 PM
NYCRISS's Avatar
These conditions may be caused from the engine wiring harness chaffing against the mounting ring on the A/C accumulator. This contact may cause a rub through to the wires enclosed in that harness, resulting in the above conditions. Damage to the harness may also result in several stored diagnostic trouble codes.
I would check that first.
Old Jul 7, 2006 | 09:54 AM
montejass's Avatar
ORIGINAL: NYCRISS
What years does this cover?
Old Jul 7, 2006 | 08:37 PM
NYCRISS's Avatar
This was for an 01 and I believe it runs from 01-04.
Old Jul 8, 2006 | 04:25 AM
mickey's Avatar
hummm, might have to do some checking on my car then to make sure i dont have this issue in the future, i have re run a coupel of the harnesses there already for simular things i see it was just waiting to be cut threw or when i put the battery in or out found a better way to run it i will check this one now to
Old Feb 4, 2008 | 01:46 PM
markym's Avatar
Had the same problem on my 02 SS and had to replace the BCM.
Old Feb 4, 2008 | 04:17 PM
RickCoMatic's Avatar
I was having an issue with my Cruise Control that got solved when the Dealer re-set the Modules.
Your first move should be to get plugged-in to a Code Reader, someplace, and see what the Code Reader says during the malfunctions.
cyndilou55
Oct 21, 2011 04:00 PM
Stardust
Sep 13, 2011 08:22 PM
lade03SS
Oct 22, 2010 03:37 PM
bubba
Apr 26, 2010 09:48 PM
86montecarloooSS
Aug 16, 2006 03:50 PM
