2000 SS temp gauge problem
Old Jan 13, 2010 | 10:43 AM
SuperSport1991's Avatar
Default 2000 SS temp gauge problem
So yesterday i hopped in the Monte and noticed after about 10 mins of driving that my temp. gauge wasnt moving. My first thougt was "Ok, its 15 degrees out maybe shes still cold." So i cranked the heat up and it was as hot as usual. Right now im leaning towards the actual gauge cluster. Any ideas?
Thanks, Owen
Old Jan 14, 2010 | 02:06 PM
seawolf18's Avatar
The gauges use stepper motors and they are known to go out. Only way to fix it is to get a new cluster.
Old Jan 14, 2010 | 02:28 PM
yeah if the gauge is whats bad than u deff gotta replace the whole cluster
Old Jan 14, 2010 | 02:44 PM
One Dark SS's Avatar
There is a post someone on here where someone posted a link, this company fixes the gauges, i beleive it was 40$/motor...
I'll try to find it again, maybe it was on an other forum i found off a google?
Old Jan 14, 2010 | 02:49 PM
it was posted by chibiblacksheep,
the site is bbengineer.com
found in this thread;
https://montecarloforum.com/forum/sh...ad.php?t=17925
Old Jan 14, 2010 | 07:39 PM
bigdomvegas's Avatar
SuperSport1991
I had the exact same problem. I ended up replacing the temp sensor twice and it still didnt work. In fact, my 2001 Monte's coolant fan would run immediately when I would turn the car on and for about 15 minutes after I turned the car off.
What fixed it?? NEW THERMOSTAT! Makes no sense because the heat was HOT HOT HOT. Try the thermostat and check back.
Ashley.Marie
Apr 9, 2011 05:49 PM
Paintballguy
Jul 13, 2010 11:25 AM
rgant_19
Jan 12, 2009 10:16 PM
smolek37k
Dec 1, 2007 07:08 PM
punkmasterflex9
Sep 5, 2007 01:25 PM
