2000 monte carlo ss tie rod issue
Old May 12, 2017 | 09:23 PM
v6racer's Avatar
Default 2000 monte carlo ss tie rod issue
So I decided that I was going to attempt to remove my control arm, steering knuckle and strut so I could replace the strut, ball joint and CV axle all in one shot except for one little issue with the tie rod. The nut on the tie rod just spins when you turn it. its not loosening or tightening just endlessly spinning. Anyone else have this issue? any idea on how I can get it off without replacing my steering knuckle?
Old May 12, 2017 | 09:37 PM
plumbob's Avatar
Try a nut splitter:
Amazon Amazon
Old May 12, 2017 | 10:38 PM
v6racer's Avatar
where can I get one?
Old May 12, 2017 | 10:39 PM
I had that happen on my Monte. I used vice grips and a breaker bar and "he-manned" that thing free.
A little more educated now, I have run into this issue again and found an easier method (thanks to the help of a local friend to let me "see the light"). GM used nuts with a nylon insert. Grab small torch (a simple small propane torch commonly used for sweating pipes that you can get at home depot will do the trick). Heat the nut and melt the nylon out (you will see it drip out). Once it it out, the nut spins a lot easier. With your problem you may still need something like vice grips or channel locks to hold the stem, but should not be a big deal once the nylon is out.
@Plumbob - Never heard of a nut splitter (I have used a grinder to remove a stuck nut/bolt before). This sounds like something worth adding to the arsenal of tricks for pesky problems like these!!
Old May 12, 2017 | 11:02 PM
l67ss's Avatar
O'Reilly carries a but splitter. Tho I agree on the torch method on this one
Old May 13, 2017 | 12:11 AM
claydoh's Avatar
a " but " splitter ?? LOL
Old May 13, 2017 | 07:26 AM
plumbob's Avatar
The Amazon link in my first post wasn't clear. You just need to click on Amazon, but here's another site: Super price on OTC Tools - 4576 at ToolTopia.com
Video:
Not to be confused with the butt splitter:
https://i.ytimg.com/vi/y85492Razzo/maxresdefault.jpg
You'll need one of these to protect from that: https://ae01.alicdn.com/kf/HTB1L6t2N...otect-Pads.jpg
Old May 13, 2017 | 11:18 PM
v6racer's Avatar
as much as I want to try that heating the nut I don't believe this is a gm toe rod on my monte.
Old May 14, 2017 | 08:36 PM
What signs do you have it's not a GM tie rod? Does it have grease fittings on it or is the nut a castle nut?
Old May 14, 2017 | 11:54 PM
v6racer's Avatar
not sure what a castle nut is but yes it does have a grease fitting on it.
