2000 monte carlo shifter sensor starting problem
Old Jan 21, 2010 | 10:00 AM
blk89convt's Avatar
Default 2000 monte carlo shifter sensor starting problem
Sometimes when i try to start my car it will turn over and not start but if i put slight pressure on the console shifter and push to the right it will start does it has a gear shift sensor that may be loose that could be causing my problem thanks
Old Jan 26, 2010 | 07:06 PM
seawolf18's Avatar
Sounds like the neutral safety switch in the council is either bad or has a loose connection.
marshagup
Feb 18, 2015 04:37 PM
Bessy
Oct 17, 2013 02:22 PM
tpayne350
Jul 20, 2013 11:19 PM
kennyjohn
Apr 11, 2011 09:57 PM
