1999 Monte Carlo Starting Problem
Old Dec 20, 2010 | 04:07 PM
kennyjohn's Avatar
Default 1999 Monte Carlo Starting Problem
The car starts fine first thing ,or when it is cold. But when the engine is warmed up,it is really hard starting. It will immediately stall,like it is not getting any fuel. Is this an adjustment I can make?
Any help is appreciated
THANKS
Ken
Old Dec 20, 2010 | 09:32 PM
zipper's Avatar
It sounds like you need a new fuel pressure regulator. Just out of curiousity, do you have a 3100 or a 3800?
Old Dec 21, 2010 | 04:52 PM
kennyjohn's Avatar
It's a 3100 it is difficult to complete this change out of the fuel pressure regulator?
Old Dec 21, 2010 | 08:30 PM
zipper's Avatar
No, it shouldn't be difficult at all. Just make sure you relieve the fuel pressure before you change it. This diagram will help to show you where it's at:
1: EVAP Vacuum Switch
2: EVAP Canister Purge Valve
3: To Rocker Arm Cover
4: Air Intake Duct
5: Throttle Body
6: PCV Valve
7: Fuel Pressure Regulator
8: To Transaxle
9: Intake Manifold
10: To Top Port of EVAP Canister
11: EVAP Canister
12: To Fuel Tank
13: To Accessory
14: To Vacuum Brake Booster
15: MAP Sensor
Old Apr 11, 2011 | 09:57 PM
olsonj's Avatar
i have a 1998 monte and it has trouble starting unless i tap the gas while turning the key....thinking maybe fuel issue???
marshagup
Feb 18, 2015 04:37 PM
Bessy
Oct 17, 2013 02:22 PM
blk89convt
Jan 26, 2010 07:06 PM
TX323GT
May 22, 2009 10:00 AM
