2000 monte carlo shifter sensor starting problem
Sometimes when i try to start my car it will turn over and not start but if i put slight pressure on the console shifter and push to the right it will start does it has a gear shift sensor that may be loose that could be causing my problem thanks
7th Gen ('06-'07): 2006 Monte Carlo starting problem
marshagup
Feb 18, 2015 04:37 PM
tpayne350
Jul 20, 2013 11:19 PM
kennyjohn
Apr 11, 2011 09:57 PM
