2000 Monte Carlo A/C
Old Jun 7, 2014 | 09:38 PM
1980Monte's Avatar
Default 2000 Monte Carlo A/C
Have a friend with a 2000 Monte and the compressor will not engage. I can jump the relay in the fuse box and it will engage. The a/c will cool. What signals the ground to bring on the relay for the clutch?
Old Jun 8, 2014 | 07:58 AM
Its more than likely low on Freon...
It may get cool... But the system has to be full in order for the compressor to kick on..
Old Jun 8, 2014 | 10:02 PM
Nightmagic11801's Avatar
and what if its full of Freon? mine has this same problem. everything new and full. i was told if it isnt ground issues it was pcm.
Old Jun 11, 2014 | 09:37 AM
vikesfan's Avatar
do a system reset....
unhook battery
take the + and - wires (which are no longer connected to the battery) and hold them together for 1 min.
reconnect and start car
check a/c
if it works, its your bcm needing to be replaced
if it still doesnt work, make sure it is not overfilled with r134a. a/c will not turn on if under or over pressurized.
billyp35
Feb 1, 2007 08:00 PM
TGAbreu
Dec 9, 2006 10:31 PM
Mike
Aug 29, 2006 10:33 PM
00pacecar
Jul 6, 2006 02:18 AM
te100
Jan 29, 2006 05:31 PM
