1999 Monte Carlo Security light on
Old Jun 13, 2011 | 08:24 AM
kennyjohn's Avatar
Default 1999 Monte Carlo Security light on
What is the deal with the security lite that is located on the left side of the dash? It came on and now I would like to figure out how to get it off,the owner's manual has little info in it about the keys.
Any help is appreciated?
Thanks
Old Jun 13, 2011 | 11:30 AM
nitehawkjcb's Avatar
The VATS is acting up. You can either a) get a new key made, and hopefully the issue will go away (the chip in your key gets worn down). If that doesn't help, you'll need a new ignition switch, as there are connectors in there as well. If you don't want to do that, you can disable it. Here's a link with instructions.
vats.likeabigdog.com
Old Jun 15, 2011 | 08:29 AM
kennyjohn's Avatar
Thanks
EbonyChevyMama
Jan 1, 2015 06:41 AM
jmarchand
Jul 4, 2013 04:08 AM
LTLDEVL
Nov 21, 2010 06:37 PM
lolligirl56
Oct 19, 2009 10:16 PM
