5th Gen ('95-'99): 1997 Monte Carlo running rough & starting problems!
Old May 29, 2019 | 12:02 PM
volkerc's Avatar
how did you raise the idle rpm? did you do it by adjusting the screw on the intake and opening the throttle blade? that will already cause problems. idle is adjusted electronically, throttle blade needs to be closed. check the egr for carbon build up, check the intake passage of the egr for being clogged.
khel72
Sep 23, 2018 10:06 AM
RedMonteCarloZ34
Aug 6, 2017 08:35 AM
randall729
Feb 17, 2014 01:48 PM
YelloJac
Feb 24, 2013 11:48 AM
mrl390
May 6, 2009 08:48 PM
