1985 Monte Carlo SS Problems [NEED HELP]
Just bought my 85 SS today has a few known problems, starting with the only gauges working are the RPMs and the battery, the turn signals wont flash but the hazards will, it seems to be burning oil from the passenger side of the motor. Would like to see what people think the problems are ill post below here what i think.
Gauges: im thinking its something in the wiring but im not sure where i could begin to check if it is or how to go about fixing it
Turn Signals: though it was a bad flasher fuse but not sure how it would be that because hazards work and looking in the fuse box there wasn't even a fuse for the hazards which made no sense
Burning oil: valve cover gasket/bad valve seats, not 100% sure on either if you know how i can be sure on what it is let me know
the oil issue is most probably the valve cover gasket. also check the intake manifold bolts. thats where i would start. change the gasket and degrease the motor.
i honestly dont recall the hazard fuse in the box and its been a few years since ive even looked at the fuse box not to mention my cars not here so i cant check for you. the flasher should control the signals and the hazards so you can rule that out. its possibly a bad signal switch. do the parking lights work?
does this car have the factory motor in it?
sorry for the out of order responses just the order i answered in.
edit: also when i turn turn signal on on the dash...the green arrow lights up but stays solid, when i push hazard switch in they both flash. i also just checked all my grounds make sure they where down good, was thinking that was cause my of gauges not working but seemed like everything was ground good
oh and obviously check the bulbs^^^^ i ruled that out because you said they flash when the hazards are on, but you should always check the simplest thing first.
there should be a fuse for the turn signals. i say should be because i honestly dont remember. you can possibly take the turn signal bulb out with the turn signal on and test the socket with a volt meter. it should have power if the switch is on. if not i would assume its the switch or a wire. id test it with the hazards on just to assure that this method works. im by no means a mechanic just the way i would attempt to test it.
the gauges could be a few things. from bad gauges, bad sending units, or just not being hooked up. the speedometer runs on a cable and thats why i asked about the odometer because if the odometer works the speedo should work unless the gauge itself is bad.
Mile has both one for turn and hazard, took a quick look at an old pic of when some one was asking about bat/ign leads,
Thinking about it I had a ground issue with my guages at one point and it was making funnything happen, found the ground down by the radio( gatta pull the stereo and hvac stuff out) was disconected
gonna run outside and check for grounds behind radio hould be (i bought it without radio, there is bunch of cut wires, mostly speaker wire didnt really look hard) and where you're pointing in that picture should i have somthing in that spot?
You might but not that I know of, that is just a Hot battery lead, I took that pic some time ago to show a different member where they could go for a constant power supply for thier radio,
ahh, i just took the front panel off where the gauges are its to hot outside to do anymore...and i looked where radio was supposed to be and i saw 2 grounds in there, 1 for radio and i saw 1 screwed in, not sure where it went to. my gas gauge jumped to almost full though and before it was just sittin on E. Also when i put it in gear the tack on the gauges dont move what soever it just sits on park.
