1983 305 monte carlo with 350 swap..what color wire is temp sensor??
Old Oct 31, 2012 | 09:15 PM
porshapower's Avatar
Default 1983 305 monte carlo with 350 swap..what color wire is temp sensor??
I have a bunch of wires from the unused wires from the original 305 engine the previous owner installed. The temp sensor on the engine has no wire going to it and my temp gauge does not work due to this. Anyone know what color wire goes to the temp sensor? Thanks so much in advance. Nel
Old Oct 31, 2012 | 09:25 PM
Im guessing its either black (standard) or could even be possibly a dark blue with a white tracer......
Memorys not what it use to be...lol im old...But im pretty sure!
Old Nov 1, 2012 | 08:30 PM
Default Thank You!
I will be by the car next week and will search for these 2 color wires and see if I can perform a miracle and make the gauge work. Thanks again so much for the reply and I will post back to let you know how well your memory still is
Old Nov 2, 2012 | 06:19 AM
Another option would be to use an after market temp gauge! That you could mount under dash..The only power you will need is for the light..
It comes with its own power lead...That you can plug into the fuse box..
with the fuse for the headlights!... That way it lights up when you turn on the headlights!
Old Nov 2, 2012 | 07:58 AM
03SSLE's Avatar
Do you have access to a library, either brick-n-mortar or online? A repair manual? Your best bet (imo) would be to locate a wiring diagram for the vehicle. Then you'll know for sure what wire is supposed to go where.
rocker38
Feb 3, 2011 04:10 PM
adamlessor
Jun 22, 2009 12:16 PM
willie8701
Feb 12, 2008 08:25 AM
smolek37k
Dec 1, 2007 07:08 PM
monte84
Jul 15, 2007 09:03 PM
