1970 monte carlo, need help
Old Sep 21, 2010 | 05:29 AM
m1k470's Avatar
Default 1970 monte carlo, need help
Missing a part on the passenger side right between the spark plugs. Not sure of the name, I know the part has a hose that goes up to the breather.
Old Sep 21, 2010 | 08:36 AM
labnjab's Avatar
I think its called the heat riser, it warms up the intake air on cold start ups
Old Sep 22, 2010 | 04:18 AM
m1k470's Avatar
I know its not the heat riser, already ordered that part. not a clue what it is.
Old Mar 15, 2014 | 03:55 PM
mowparz's Avatar
It may be the heat stove shield, which works in conjunction with the heat riser, which is a spring operated flap door that is located within the right side exhaust manifold. The heat stove shield covers the manifold and gains heat which is delivered to the carburetor by a "semi flexible" tube / hose which is about the only thing I know of to be located in that area.
Tom.
Mar 10, 2017 06:57 PM
Caps
Oct 17, 2013 05:26 AM
shygirl111062a
Jan 7, 2009 12:24 AM
BeachBumMike
Mar 20, 2007 08:43 AM
Lord_Hate
Jan 21, 2007 07:53 PM
