07 traction control
Old Sep 6, 2010 | 08:09 PM
lanniec's Avatar
Default 07 traction control
Message to check traction controll then go out when driving.What's up with that help!
Old Sep 6, 2010 | 09:00 PM
possibly a bad ABS speed sensor in one of your front wheels? I have the same message also. I thought it was nothing because it came on briefly and went out but it is on all the time now with the ABS light also. I've been told that the sensor may need cleaned, but I haven't had a chance yet. The below is a message that I received from one of the members here, I hope it helps......
Originally Posted by RocknSS04
Your ABS light probably came on because of corrosion in the connector of one of the front wheels. You didn't say, but I'm guessing your traction control light came on also, unless you don't have traction control.
If it continues to happen take the connector apart and clean it with some contact cleaner, or even wd-40 and re-assemble.
Old Sep 6, 2010 | 09:02 PM
lanniec's Avatar
thanks!
Old Sep 7, 2010 | 09:04 AM
MillerMonteSS's Avatar
2010 Monte Of The Year
My ABS light and Traction Control lights came on after I had a minor accident. The connector on the driver's side strut tower came loose. I plugged it back in and all was well. Good luck.
Old Sep 8, 2010 | 09:22 PM
lanniec's Avatar
Thanks guy's i will check the plug's this weekend you boy's always come throught !!
mwmarshall
May 14, 2022 02:43 AM
Chris s
Jan 27, 2013 04:30 PM
Jul 8, 2012 08:27 AM
willysmith
Mar 16, 2006 07:50 PM
Bob50th
Jan 7, 2006 09:46 AM
