7th Gen ('06-'07): 06 SS abs/traction control
Hello, my 06 Monte has traction control and abs lights on when turning the wheel or going over bumps. I had the Code read and it come up as right side wheel speed sensor. I replaced the hub. Now both lights are staying on. I have checked all the wireing everything seems secure and tight. any thoughts of what could possibly be tripping these codes? Also, I am getting an occasional grinding type noise from the front end on take off, almost like the the abs is getting stuck on momentarly. And now the speedometer is jumping when at idol. Need help ! Thanks in advance for any advice.
mwmarshall
May 14, 2022 02:43 AM
Chris s
Jan 27, 2013 04:30 PM
tridski
Jun 26, 2006 09:55 PM
