06: Reving up to the Challenge...
Old Mar 10, 2008 | 03:47 AM
MrDanger's Avatar
Default 06: Reving up to the Challenge...
Hey everyone,
Maybe you can help me, since purchasing an 06 SS I have found that doing any type of work on these cars are extremely confusing and very time consuming with the way cars are manufactured these days so I come to you for some advise.
A few weeks ago I was out with some friends and another friend pulled up along side of me at a light and started reving his engine, so I to put the car in neutral an tried to rev up. The car made it to around 2000 RPMs and kinda just....stopped, the car was running it had power there was no issue with it taking off and I clearly smoked him off the line, but when I got home I put it in park and reved up again, even in park you can't get this car to get over 2000 RPMs. What's the deal? Is there a way around that? It was quite embarrassing to not be able to rev to the occasion.
help me out, the car under the hood is completely stock.
thanks for any help.
Danger
Old Mar 10, 2008 | 05:10 AM
bowtietech's Avatar
Default RE: 06: Reving up to the Challenge...
There is a RPM limiter incorporated into the ECM's software calibration that limits how far the electronic throttle can open when in park & neutral.This is in place to protect your engine from over revving.My '07 SS is limited to 3500 RPM in park/neutral. This can be changed with a tuning program such as HP Tuners. Changing ECM parameters using tuning software programs is something that should only be done by someone that has experience in this area. Inexperience in this area can turn your ECM (Engine Control Module) into an expensive paper weight!!
Old Mar 10, 2008 | 01:41 PM
MrDanger's Avatar
Gotcha'
I figured as much, man it sucks. But what can you do, I'll just show someone who revs up on me the business off the line thats all.
Thanks for reply
Danger
Old Mar 10, 2008 | 02:15 PM
God_Bot's Avatar
Didn't realize they were set at different limits though. My 3.9L will rev up to 4k when in park/neutral, got it past once or twice and have no idea how I did so.
Old Mar 10, 2008 | 05:57 PM
red06SS's Avatar
Mine is an 06 and it goes to 3500 rpm. Yours should get past 2000 i would think. Either way you put exhaust on it and it sounds really nice!!!
Old Mar 10, 2008 | 07:51 PM
MrDanger's Avatar
Yeah I could be wrong about the 2000 RPM, it's been a while since I've reved. You guys may be right.
Thanks for the responses.
Danger
773 Z34
May 31, 2012 04:31 PM
1996Monte_Carlo
Apr 29, 2011 07:08 AM
mickey
May 5, 2008 01:40 PM
Cowboy6622
Jan 5, 2008 06:53 PM
06ltz
Jul 14, 2006 12:10 AM
