06 Air Conditioning
Old Oct 7, 2009 | 04:11 PM
llub5's Avatar
Default 06 Air Conditioning
Hi All,
Does anybody have a wiring diagram for a 2006 Monte Carlo air conditioning system? I have the schematic in the Haynes manual, but it does not go into enough detail. Any help would be greatly appreciated. Thanks.
-Dan
Old Oct 12, 2009 | 06:55 PM
monte07's Avatar
can you describe the problem as well? did some one think i would think it would be funny to cut the wires or did some thing happen to the ac to make it not work? did you have some one check the level of r134a in the unit? that would make the ac not come on and would make you think it would be the wiring? thats what happened to my silverado thaught it was the wireing and gigles my dad put a can of r134a in and started right up. check the level by a shop if you need more thell add some if youll need it. pepboy's will charge 90.00 for the check
Old Oct 17, 2009 | 08:45 AM
llub5's Avatar
The problem is that when the A/C is on and the recirculating switch is selected to use outside air the recirculating actuator makes a loud clicking sound. Occasionally the air temperature control actuator does the same thing. Both the temperature control and recirculating controls work, but it jus sounds like the actuators are being driven against their stops for about 30-60 seconds.
MeatShield72
Apr 20, 2008 01:51 PM
bcarson
Aug 23, 2007 08:35 PM
bzapp
May 7, 2007 04:29 PM
zipsayain
Jul 12, 2006 12:19 AM
zipsayain
Apr 23, 2006 12:34 AM
