04 heater core replacement
Old Dec 20, 2011 | 11:29 PM
gottarace's Avatar
Question 04 heater core replacement
Ok, I am sure this has been covered already.
I am about to change out a leaking core and after seaching the web. says something about plastic tabs that need chielsed off.
anybody changed 1 out or know of a post or guide I can review?
Core is ordered and will be picked up in the morning.
Thanks all...
Todd
Old Dec 21, 2011 | 05:42 PM
kingreyna's Avatar
I'm in the process of replacing mine in my 06 but its a bit more complicated than the 00' -05. I have to take out my seats , center console, pull down carpet to get to mine cause of some ducts underneath. Your's don't require that. I have both Haynes manual I can probably scan you the how-to and send it over. Its pretty straight forward.
Old Dec 22, 2011 | 12:19 AM
I did mine when I first got my car. Once you get it apart you will see what they are talking about. They look like little plastic rivets and they are kind of a pain. I left my seats in but if i did it again I would probably take them out. Also when you get the heater core the tubes rotate 180* so compare it to the old one and make sure they are correct before you try to put in. It's a fairly easy job, kinda back breaking but not terrible over all.
2003 SS
Sep 24, 2017 08:38 AM
Budsjlm
RWD Tech Guides '70-'88
May 25, 2012 07:14 PM
1BLACKMONTE
Aug 1, 2011 06:38 PM
LRS
Jan 17, 2011 10:46 AM
98Z34
Mar 16, 2010 05:50 PM
