03 Monty light issues
Old Oct 24, 2014 | 08:09 AM
K goyer's Avatar
Default 03 Monty light issues
I have a 2003 monte carlo and I recently noticed that my door panel lights only partially work and when I switch from low to high beams I sometimes lose all lights. How can I find out what the problem is without having to pay a garage?
Old Oct 26, 2014 | 10:26 AM
Sounds like a bad/faulty Multi function switch/sensor.
Do you have brake lights?
Since the problem changes when you use high/low beams...
Im gonna say a Multi function switch.
A quick check...
Using the brakes and or turn signals...
Try jiggleing the turn signal and see if the tail lights flicker etc..
If they do...that's the problem.
thefuzz
Jun 28, 2011 09:50 PM
Pete20
Mar 23, 2008 04:35 PM
wally
35
Feb 22, 2008 08:57 AM
jamiermr
Jan 27, 2006 03:53 PM
OZONEDDDDD
Oct 11, 2005 06:30 PM
